rchippie
rchippie's Avatar
11.13.2007, 08:58 PM
I was at work today & got to thinking. Would the traxxas venolin system be any good in my crt.5 Or is the MM a better choice ?.
REAL MEN RUN BRUSHLESS
11.13.2007, 09:02 PM
On 2s the velineon will be slower than the mm. Plus the velineon esc does not have much (if any) programability. I have owned both and consider the mm esc to be very superior.
rchippie
rchippie's Avatar
11.13.2007, 09:07 PM
thank's again . i just saw the venolin motor is only 3500 kv. I'll just get the 570 MM system from my friend's store.
rchippie
rchippie's Avatar
11.15.2007, 01:08 PM
i just talked with brian g & he suggested not to use the mm motor but to use a feigo s motor. He said a 7s with a 15t pinion would be good for around 35 with the kit tires. He also said if i wanted to use truck tires that a 8s with a 14t pinion would be good. He also said these motors would not get as hot as the mm motors because they have a little more torque. So im probably gonig to get a 7s motor. what does everyone think ?.
11.15.2007, 01:17 PM
Well if you do not want the mm motor, the feigao s can is a better choice. I have a stampede with a 12s on 3s lipo and it has run better than any other small motor I have tried. I have pitted it against the mm motors, the velineon motor and a few others. If you look I posted a thread that shows the internals of the mm motors versus the vxl motor. Both are smaller than the feigao s can.
I have a slightly used (2 runs) 7s motor here, If you want it send me a pm. Nothing wrong with it, just too high kv for me as I am going to 4s and higher systems.
rchippie
rchippie's Avatar
11.15.2007, 02:44 PM
Ygpm
rchippie
rchippie's Avatar
11.19.2007, 12:23 AM
I would like to post a couple of pics of my crt.5 conversion so far, but i dont know how. Can i email them to some one to post for me ?.
