squeeforever
squeeforever's Avatar
11.15.2007, 05:45 PM
I'm pretty sure the 22 series has a different pattern, but if theres enough adjustment, I guess you could make it fit, given the size of the screw holes are right.
lutach
lutach's Avatar
11.15.2007, 06:35 PM
Yes, the pattern is different, but in a way that you can actually have 2 of the hole line up perfectly. I'm such a retard for not noticing this before. There are 9 holes total and if you choose one of them and use the third hole from the one you chose, you end up with a 25MM spacing.
