It depends what you're going for. If you want all-out nitro-beating speed, go for the 5700, but it will run hot and may thermal sometimes. If you want a more reliable setup that will run cooler but not be as fast, then get the 4600.
I can't help you with the gearing, since I've never had a Jato.
