FLM Skids
Ninmaxx
FLM Skids - 11.17.2007, 04:20 PM
Is the FLM skids on Rcmonster the new versions, I think the old pic is still up there but I want this version.
http://www.fastlanemachine.com/Publi...9/Default.aspx
Serum
Serum's Avatar
11.17.2007, 05:01 PM
You will get the new version if you order them. No worries..
Ninmaxx
11.17.2007, 05:29 PM
Okay thanks.
squeeforever
squeeforever's Avatar
11.17.2007, 09:16 PM
I have a FLM question to. :p
For $24 (I think?), do you get both shock towers? I would assume so since theres a difference from the front and back, but that seems almost to good to be true...
Ninmaxx
11.17.2007, 09:32 PM
No you only get one.
11.17.2007, 09:33 PM
Im fairly certain I paid $24 each when I got mine back along (and then went with the G3.3 towers anyway). The new ones take 3.3spec body posts dont they?...
Ninmaxx
11.17.2007, 09:36 PM
I'll find out if they do take 3.3 post in a few days. I'm making a big order of FLM parts for my FLM maxx.
squeeforever
11.17.2007, 09:58 PM
That does about right. I guess you get one of each when you order 2...Or do both the front and rear have the wing mounts built in? I'm fairly certain there are two different towers.
11.17.2007, 10:08 PM
Hmm, when I ordered mine, both had the same wing mounting holes in them- guess its easier & cheaper to use a universal design, rather than make a seperate tower for front & rear?...
GorillaMaxx360
GorillaMaxx360's Avatar
11.17.2007, 11:14 PM
yep both mine have the wing mount holes too
squeeforever
11.17.2007, 11:49 PM
Yea, it was just my imagination....It doesn't like me to much...
Serum
Serum's Avatar
11.18.2007, 04:52 AM
The front and rear towers are the very same; no differenes. Both come with the wing mount holes. The ones you get from Mike use the square body posts too. The square body posts limit your shock setup options.They stick out out of the tower. With 4 shock or 8 stock shocks this is allmost no issue, but with proline bigbores (who don't work with 3.3 shafts anyway) and UE shocks you can get into trouble.
And for 24 usd, you'll get 1 tower.
