MGM li-po low voltage cutoff???????
david lamontagn
MGM li-po low voltage cutoff??????? - 11.19.2007, 01:47 PM
I've a MGM 16018 and i've programm it with USBCOM+ (very easy!) and i've set the batterie type to 4s li-pol, but, i've don't see at any place in the user manual or in the program about a low voltage cutoff.
So could you tell me if the MGM 16018 have a li-po low voltage cutoff???
The only thing i can see is if i set the controler for 4s li-po, automaticaly the controler will cut the voltage at 12 volts.
But realy not sure because they not mentioned any information about it...
Thank you !
David
