highflier
Emaxx- FLM wannabe
11.22.2007, 07:27 PM
If you want maxx play time and it's not hard core competition the A123's are the way to go.
Make it a 6s2p pack... (12 cells)
For the 3 packs you listed that means you will have 6 cells left....
If you do your setup right you can charge the 6s2p pack in under 10-15 min. and the charging system is super cheap!!! Therefore you could run the remaining cells 6s1p. while the others charge. You will be a little heavier.. but with 6s2p there will be tons of power availible.
Now if you are going to the track to race, You'll want to shed the weight, and your run time requirements will be lower, So lipo's would be your best bet. You can pick up some charge between races and should have no issues with several races with a single pack.
I personally went the A123 route... but If I start going to the track I will get a set of lipo's to race with.
In Conclusion. Buy which ever matches your use plan.
Highflier
