HiTec 5995TG (happy medium and probably best for Losi 8ight-IMO) Also Tower Hobbies now has a copycat version of this servo that looks promising. Normally I won't even consider their products, but this one doesn't look bad: http://www3.towerhobbies.com/cgi-bin...7&I=L37024&P=K
All are overkill for torque.
Better overkill than on limit!
I have servo Airtronics 94359Z took it from buggy and put it to truggy once i felt that servo start to heat up and then its heating its going slow. I thought that time is come to this servo, took it apart and took motor also apart and i seen that collector was burned, i polished with thin sandpaper and cleaned it assembled again and now again like new. Burned collector is sign that servo works on limit. So I put it back on buggy and bought Hitec 5955TG for truggy and no any issues on 1.5year.
i have always used hitec servos (numerous 645mg's, and my current 5955tg) but just lost my first 645mg. it was on my crawler, and i don't believe i had the EPAs adjusted properly (surprised i didn't lose the other one on there).
the 5955 is an absolute beast, esp. when fed 6 volts. i'm using that on my eXT8.
well i will agree that hitec has come a long way they do make some really good servos. but i do think that alot of servo problems are because people dont set there end points an travel.
I am using a JR Z9100T in my Revo and it works very well, super fast and can turn the truck if you hold the front wheels!
I run it and a futaba 3050 (for brakes) in my tekno converted revo with a ccbec set for 6.5 volts! Neither servo even gets warm, so I can recommend both for use at 6.5v.
I will say that the JR is alot quieter than my hitec 5997 that is in my LSP. I have witnessed the "knock off" servo that sspconcepts was talking about and it works as well as the hitec it is based on, only maybe a little louder!
I have had excellent success with futaba servos, both their brand and the ones they relabel for other companies. However I have never used a servo that did not have enough torque for the job!
