othello
HV basher
11.25.2007, 04:37 PM
EDIT: The 18650 cells i use (shown on the previous picture is a Sony 18650VT cell). The cells in the VPX packs are different ones from A123 and do have the same size.
@Zeropointbug
I never intended to turn your thread in a cell discussion thread. Sorry for this. And no those aren't A123 brand cells in 18650 size (however those do exist too), these cells are Sony brand cells.
Those lion cells can be found in battery packs for Bosch power tools. Ebay: "bosch 36v". There is one pack with 2,0Ah which contains 20 Konion 1100 (1100mAh) cells. And there is a newer one with 2.6Ah which contains 20 Konion 1300 (1300mAh) cells. Both cells share the same 18650 size. I got the 2.0 Ah pack for 65 Euro (3,75 Euros per cell) a few months ago.
Konion 1100mAh (Sony 18650VT): some information in german with discharge graph
Konion 1300mah (successor cell): some information in german with discharge graph
As you can see those cells can only be used in our type of application when used in paralell as they are only good for bursts between 22-26A. I used them as 4s4p (80-100A bursts) and later on as 8s2p (40-50A bursts). Their main advantages are: they are cheap, they won't drift and get out of balance. Absolutely no balancer needed, they can be charged with your typical lipo programm (4,2V per cell @ 1-1,5c), they have a 3 to 5 time higher life cycle compared to lipos. BUT: They won't hold voltage as good as A123 and can't absolutely not be compared with todays lipos (power wise). The voltage curve constantly drops during discharge.
Here are some eagletree graphs from 2 consecutive runs i made on the same track. One with 10s1p A123 and one with those 8s2p Konion 1100. Outside temp was low (7°C or 44°F) and i used the konion pack as my last pack (so it was the coldest one).
A123 10s1p (800 gr, 1.76lbs): complete run, 1 minute in detail
Konion 1100 8s2p (720gr, 1.58lbs): complete run, 1 minute in detail
As you can see the Konion pack power output is inferior compared to my A123 pack. They max out at about 1150 Watt (72 Watt per cell). The A123 setup is good up to 2300 Watt (230 watt per cell). The voltage curve constantly drops as does your top speed during driving, this is almost not the case with A123 cells. When using my A123 setup i can make wheelies on command but not with the Konion setup. On the other hand the car is more controllable with the konion setup and is good for training purposes (and for low grip surfaces where torque is not essential).
So for those high power guys those cells are no good. But for low to medium performance purposes they do work out and are a cheap and maintainance free way to get your car moving.
