Serum
Serum's Avatar
11.26.2007, 04:13 PM
Hi Habit;
No, the brass pins as you call them actually are little hardened pins. They prevent the slipperplates to slip on the pressure plates. You should use both the slipper plates and the pressure plates.
Yes, you are correct. The slipper pads can fall right off.
