I'm not sure if it is the red or blue loctite. Its whatever Losi uses straight from the factory. Im going to try the heat tonight. I have a 100W soldering iron with a big tip I'm going to try. Ill post the results. Thanks for the suggestions.
I had similar experiences with Losi's loctite. Luckily I was able to rotate the part free from the chassis (It was the brace between the center skid and main plate, 1 screw was left which has stripped)
I wonder why Losi sticks to these tiny hex screws/wrenches? They're way too weak for unscrewing them while being secured by loctite.
