rchippie
rchippie's Avatar
11.29.2007, 05:53 PM
I started having issues with my new MM today.When i pulled the trigger the car would take off, then it seemed like it would cut on & off rapidly i tried reprogramming it that did not help. So i called castle Thomas helped me diagnose the possible problem. After checking it with another motor it did the same thing. so he said the esc was the problem . So he is sending me a new one. This was only the second time i used it. He also said that usually if a esc is not going to work properly it will usually happen in the first couple of uses.
REAL MEN RUN BRUSHLESS
