which would be better?
which would be better? - 12.01.2007, 04:15 PM
would the lehner 1950 or 2230 better suit the lsp for racing and all out insane power? 6s lipo and oemrc esc will be my setup.
12.01.2007, 04:22 PM
The 1950 should be plenty- the 22 series are designed for 1:5 vehicles; they would destroy the driveline of a 1:10-1:8 in a second probably!
12.01.2007, 04:52 PM
its settled then! 2230 it is! the 2230 is lighter, cheaper, and puts out 3000w at 60a whereas the 1950 puts out 3000w at 100a.
Patrick
Patrick's Avatar
12.02.2007, 12:38 AM
It doesn't really work like that. Watts = Amps x Voltage. So 3000w and 60 amps would need 50v. 3000w and 100 amps would need 30v.
12.02.2007, 12:41 AM
K so the 1950 is better
Patrick
Patrick's Avatar
12.02.2007, 01:13 AM
What? I'm not saying the 1950 is better, I don't really know much about either of them. The 60a and 100a thing doesn't say which is better. If they are both rated at 3000w then that means they can both put out the same amount of maximum power. I'd be surprised if you could pull 3000w burst in a truggy off-road. Even if your batteries have enough power, you'd probably brake traction or flip over backwards before you get 3000w.
Do you understand what I said in my first post?
nl12
nl12's Avatar
12.02.2007, 07:12 AM
1950 is better for your application
starscream
RC-Monster TQ
starscream's Avatar
12.02.2007, 07:53 AM
You would have to make a custom motor mount for the 2230 because the screw pattern is not standard, so I'd say the 1950 is your best bet.
Ha Ha
12.02.2007, 01:12 PM
alright, i get what you said patrick but the other guys think the 1950 is better, i guess ill go with that if theres no other opinions.
squeeforever
squeeforever's Avatar
12.02.2007, 01:37 PM
No, I don't think you get what he's saying. He didn't say one was better than the other.
I personally would get the 2230. It will draw less amps, which with the airplane esc is vital.
12.02.2007, 03:17 PM
the oemrc esc is rated at 100a, and i finally re-re-re-reread patrick's comment and i think i finally got it! id personally rather go with the 2230 as well because 1. it draws less amps 2. its a mild motor for a 1/5 scale, and if i ever build my brushless 6x6 mgt, that motor would be well suited for the application.
squeeforever
12.02.2007, 05:17 PM
It doesn't matter if the motor is rated at 60 amps or 100. It will pull less amps, but the thing to be concerned with is the burst the ESC can handle. Just because an ESC is rated at 100 amps and the motor at 100 doesn't mean it will be ok. The burst on that ESC is something like 120. The measly MM can handle 200 amps burst. Airplanes don't have burst that high, but cars do...
12.02.2007, 09:07 PM
whats the max burst on the 2230? the 1950?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.03.2007, 12:23 AM
I would use the 1950.. it has lots of power... look at lehners website...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
