jnev
jnev's Avatar
12.03.2007, 10:56 PM
Can't really comment on the ESC's very much, but as for the Neu's, I think a Neu 1512 motor with about 2200KV or similar would work great in the buggy on 4 lipo. If you go with a Feigao, I'd actually go with a 9xl instead of the 8xl because it will run cooler, yet there will still be plenty of speed. The MM and 9xl would work great, but the reason it is so much cheaper than the MGM/Neu or Quark/Neu combo is because of the efficiency. It will run a lot hotter in a shorter amount of time than the higher end set ups.
