Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
MetalMan
MetalMan's Avatar
12.08.2007, 01:45 AM
One thing I noticed with the 80amp ESC, if I had the wheel turned and tried to start from a dead stop, it didn't like that for some reason. Voltage drop from the internal BEC being loaded? Well that's gonna be a thing of the past too. I will install the 10 amp CC BEC as well. This will also remove ESC heat added by the internal BEC.
If your theory isn't correct, another one would be that with the wheels fully turned, the front driveshafts are binding a little bit (happens with many trucks/buggies), causing an increased initial load to the motor. As you know, any extra load on startup will not help with cogging.
