DrKnow65
DrKnow65's Avatar
12.09.2007, 08:35 PM
I think the 5700KV on 3S will definatly be too much. The lower KV motor is a must. But I am going to give it a go with the 5700KV before I get another motor.
I'm thinking that slipper adjustment is going to be a big deal. I'm planning on having diff issues too and I've already got the steel outdrives, new rings, and carbon steel 3/32" diff balls on order.
I was thinking I might try a NEU 1506/3Y or mabey even an 1115/1.5Y (380 size) to lighten up the elecronics side of the chassis so I woulnd't have to run a heavy lipo or add weight to balance it out. Run it with a small 2500Mah EVO25 4S, or a MaxAmps 3000HV 4S. Then I could move around components to perfect the weight displacement?
