PhaedruS
12.15.2007, 09:02 PM
Hey Phraedrus, your idea sounds much like THIS.
Kinda yeah- but I need to design a cage or plate system that will hold the center diff assembly in position floating at or below where the old tranny used to be in a Revo. I am picturing a fitted plate that will trace around the opening of the tranny area and have struts reaching in to hold the center diff in place. the rear of the motor will need a brace as well because the torque will twist the assembly out after awhile. I'd like to integrate an overhead roll bar into this structure as well to aid in bracing and to protect the high center BL motor.
