jhautz
jhautz's Avatar
12.16.2007, 09:34 PM
Originally Posted by teknorc View Post
Hi,
With a low kv motor and an 18t clutch bell, it will be hard to tune the clutch as you would normally. You may need to remove 1 or 2 springs for it to engage at low RPM and still grab without slipping. The clutches need a nitro RPM range to function correctly. You shouldn't have any trouble getting it to work, but you will need to set it up a little differently.
That said, I really like what you've done with it. Turning the diff around and using the RCM mount will eliminate flex issues so your metal to metal contact should be trouble free. Definitely keep us posted (you too David :).
I think it will be OK. I'll probably just run the .9 or .95 springs if it doesnt grab the way I want with the 1.0 springs. I will be running a 1306kv motor, but it will be running on 5s so it will still get up to 24-25K rpm. It should be fine I hope. If I do run into that as my barrier to making it all work. I can always find a motor with a little higher KV. I have some in the 1500-1600kv range too. I'll for sure keep this updated as I make progress.
Originally Posted by Matthew_Armeni View Post
In this picture i looks like your clutch bell is too far away from your flywheel, not all of the clutch shoe will be in contact with the bell. You should install a shim behind the flywheel and collet to move it forward, I had to do this on my Revo conversion. Looks really good, I like the RCM mount idea, I may try that on my 8ight because its diff is already facing that way.
Good eye... Yea your right about that. I just put it together for fit up and testing the layout. When I put it together I saw that it needed some adjustment, but I didnt feel like messing with the springs again so I just left it for now. Those clutch springs are a PITA. I'll fix it before running it. It will be a few weeks before I get much time to play with this again and finish it up with the hollidays coming up. I will have people in from out of town and then be traveling for a few weeks fr work. I'll be lucky if I get to it again by late January.
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
12.18.2007, 03:35 AM
Little update. I think I have the brake servo sorted out. It still needs to have some of the linkages shortened to neaten it all up and I am still missing some screws and using less than ideal screws in other areas just because it was what I had at the momnet, but I just assembled it to test the fit up and see if the mini servo was going to be powerful enough. I'll clean it all up later with the proper fasteners and correct length linages and all.
The goal was to come up with something that would be a compact setup that would take as little valuable chassis space as possible and add as little weight as possible. Again... Thanks for the suggestions Mike!!
It can hold the tires locked up when I drag it across the carpet so that should be enough to lock up the tires on any dirt surface. Something I really like about it is, the whole assembly will lift right off for maintenance of the diff just by removing the screws that take the diff top plate off. It all just stays together as one unit. It also gives me easy access to the thumb screws for adjusting brake bias. It should be just as easy to dial in the brakes as it is on a conventional nitro setup.
I made a carbon fiber servo plate that mounts to the center diff top plate and mounted the mini servo into it. I then made a lever to attach the the linkages to and used it to reverse the pull direction so I could pull the brake cams in their natural direction. I'm also using the lever arm to generate a little more effective torque by mounting the servo linkage to the farthest out hole on the lever and mounting the brake linkages to a hole a little closer in to the pivot point. I used .125 in. CF plate and it all seems very sturdy. I guess I won't really know until I land a few jumps and crash a few times, but I think it will be robust enough to withstand the abuse. At least I hop it will.
Anyway here are a few pictures. Its tough to explain and the pictures will do a much better job.
to make it...
or break it...
Silent...But Deadly
starscream
RC-Monster TQ
starscream's Avatar
12.18.2007, 07:32 AM
The HS5245 has the perfect size/weight/power for bashing but for racing, I've been using the HS81MG for a few years now. Its all about leverage
I am also ONLY using rear brakes. You still get some front braking power from the center diff but not much (depends on how heavy the diff fluid is)
I also picked up a Electrik-Clutch adapter. What type of clutch shoes and springs are you using?
I plan to run without the clutch springs so that the shoes will engage sooner.
Ha Ha
jhautz
jhautz's Avatar
12.18.2007, 01:09 PM
Thanks for the comments guys.
Kits are for the pros like Mike or Tekno to deal with. I think Mike is working on his own (probably much better) Elektri-Clutch setup in a 1/8 buggy to see how it works. If it does work well, I'm sure there will come a time when sombody makes kits, just like the direct drive setups now. But at this point I havent even seen a 1/8 with a fully functional clutch setup in it yet, so who knows if there is even a benefit to it yet. This may all be just a big elaborate waste of time.
HS81MG Wow thats a small servo for stopping a 1/8!!! Pretty impresive! You are right though, its all about leverage. I think the HS5245 is small enough for me for now though.
I'm using the M2C 3 shoe Revo clutch setup with the .9 springs and Med. shoes. I bought this kit http://www.m2cracing.com/product.sc?...&productId=175 and turned the flywheel down to the same diameter as the clutch bell because It was in the way and I couldnt make it fit anywhere.
to make it...
or break it...
Silent...But Deadly
starscream
RC-Monster TQ
starscream's Avatar
12.19.2007, 12:57 AM
jhautz,
I made a custom clutch back in January and it was definetly not a waste of time.
Here's the link for those that don't remember or never saw it: http://www.rc-monster.com/forum/showthread.php?t=5265
Anyway, I gave up with the project because the Losi 8ight did not have enough room for batts with the configuration I had as well as the motor temps were pretty high. I never tried running the shoes in reverse though.
I'm going to give this a try again with the Electiclutch because this adapter seems a little more freindly than my custom setup.
I guess I should have put a patent on it back then :)
Ha Ha
entjoles
12.20.2007, 06:55 PM
have you put any time on this set-up yet, how is it working??
i just won a xray truggy and am getting ideas
jhautz
jhautz's Avatar
12.20.2007, 07:58 PM
No... No its not running yet. I have a couple little parts that ordered and I'm waiting for still and I need to get a battery tray worked out and the whole thing wired. I doubt I will spend any time on this untill after after the new year.
I'm pretty much booked from now untill January. Really sucks cuz I'm die'n to see how it works as well.
to make it...
or break it...
Silent...But Deadly
