12.17.2007, 02:25 AM
hey didn't mean anything bad about the clutch setup. just not to sure how well its going to work out. i would really like to know how well it works when your done.
as for the controller/ battery the main problem is that its just going to be pulling alot of amps. the mgm 160 can do 160amps at full throttle an 200amp burst. so your going to need a pack that can handle that kind of amp draw. i found out that if i gun it really hard then it cuts off at half throttle or higher. but if i roll into the throttle then im fine.
