Patrick
Patrick's Avatar
12.17.2007, 10:18 PM
I have the flightpower balancer (non trackpower version). To allow it to start charging you have to hold the mode button until the two white arrows up the top turn orange, then it's in connect mode and the charger should recognize there's a battery there.
I don't know if it has a timer or not, I've never noticed. I do like the flightpower balancer better than the hyperion though, except that it can't do A123's, which I don't use anyway.
ssspconcepts
ssspconcepts's Avatar
12.17.2007, 11:28 PM
To all,
Thanks for all the feedback and info...however, after a lot of trouble shooting I discovered that I had a bad deans connector (first one ever for me). In short the connector was okay...until you plugged a male connector into it...for some reason the circuit would "open" and the charger would give me the "Err b l" because it couldn't "see" the battery. I replaced the connector and presto...problem solved. Thanks again for the recommendations though.
