ncalenda
Need for Speed
ncalenda's Avatar
12.18.2007, 05:17 PM
I suspect it is the batteries, the LVC will trigger when I'm on it hard. If I don't run WOT then it doesn't trigger the LVC.
My guess is that under heavy load (e-maxx running 5S, weight 12lbs) that the voltage dips low enough to trigger this problem.
If it is not the batteries, then the MGM is triggering it too soon.
  Send a message via AIM to ncalenda
