highflier
Emaxx- FLM wannabe
12.19.2007, 11:51 PM
A lot of claims but we have to wait and see where the rubber hit s the road so to speak.
If the claims were valid, Cooling would not be such a issue.
1) Lets just double the MAH and double the Voltage
This will give you 4 times the run duration, Less heat, Less weight.
2) Buy a second pack.
Say you used to run 20 Min. Now you run 1 hour 20 min on a pack and have a more agile vehicle. Since it is running higher voltage you will have cooler electronics.
The biggest issue may be finding motors with a low enough KV to run good on 44 volts. Opps need some new ESC's to go with this.
Highflier
