12.20.2007, 02:55 AM
Any 20c rated lipo will do the job, preferably 5000mah or higher.
The tekn kit does not require any holes, but you would need to convert over to a single servo for steering. You could also buy a RCM motor mount, and just buy the tekno battery tray and straps. I like the tekno esc mount as it gets the esc out of the way. With an 8xl you could lock the revo in second gear and then use the motor to brake and have reverse. Pulling open the tranny is not bad, just have an exploded diagram handy for reassembly. If you have built robots this should be a walk in the park!
