snellemin
2 KiloWatt RACER
snellemin's Avatar
12.20.2007, 08:58 PM
sweet deal man. The mamba does great with low kv motors, but I have the same issue like you when I use my 7800kV LRP.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
lutach
lutach's Avatar
12.26.2007, 02:41 PM
I'm also going to have some Brushless ESC for 1/18, 1/16 and 1/14 scale. This little guy has the following Specs:
Specifications:
40 Amps maximum continuous current rating (at 25℃ ambient temperature with proper air flow)
Input: 5~18 cell Nixx or 2~7S A123 or 2~6S Lixx
2 Amps BEC (maximum input with BEC limited to 9 cell Nixx or 3S A123 or 3S Lixx)
Dimensions: 40 X 24 X 14 mm
Weight: 23g (including leads)
Features:
Proportional forward, brake and reverse
Proportional control of starting torque by throttle trigger – the starting
torque can be tremendous high or incredibly low
Extremely smooth startup and low speed operations
Programmable throttle curve, acceleration rate, motor timing, low
battery cutoff voltage, reverse power limit and drag brake strength
Easy and fast stick programming with ‘skip’ and ‘read back’ features
5 programmable operation modes (please refer to the table below)
180,000 RPM theoretical speed limit for 2 pole motor
Lost signal protection
It has the following settings:
1: Throttle Curve:
Option 1 (30% Reverse Exponential)
Option 2 (15% Reverse Exponential)
Option 3 (Default) (Linear)
Option 4 (15% Exponential)
Option 5 (30% Exponential)
2: Acceleration Rate:
Option 1 (Very low)
Option 2 (Low)
Option 3 (Default) (Normal)
Option 4 (High)
Option 5 (Very high)
3: Motor Timing Advance:
Option 1 (Very Low)
Option 2 (Low)
Option 4 (High)
Option 5 (Very High)
4: Operation Mode:
Option 1 (Mode 1 Forward with proportional brake and stop lockout
Reverse with proportional brake and stop lockout)
Option 2 (Default) (Mode 2 Forward with proportional brake and stop lockout
Reverse with proportional brake to stop then Forward (no lockout))
Option 3 (Mode 3 Forward with proportional brake to stop then Reverse (no lockout) Reverse with proportional brake to stop then Forward (no lockout))
Option 4 (Mode 4 Forward with proportional brake only (no reverse))
Option 5 (Mode 5 Forward and Reverse with adjustable Drag Brake (for Crawlers or Tanks only))
5: Battery Type:
Option 1 (Nixx)
Option 2 (A123)
Option 3 (Default) (Lixx (Low) (2.8 V cutoff per cell))
Option 4 (Lixx (Medium) (3.0 V cutoff per cell))
Option 5 (Lixx (High) (3.2 V cutoff per cell))
Item 6: Low Battery Cutoff Voltage:
Option 1 (Nixx 5-6 cell (Disable), A123 Not applicable, Lixx (Low) Not applicable, Lixx (Medium) Not applicable and Lixx (High) Not applicable
Option 2 (Default) (Nixx 7-8 cell (6.0 V), A123 2S (Disable), Lixx (Low) 2S (5.6 V), Lixx (Medium) 2S (6.0 V) and Lixx (High) 2S (6.4 V)
Option 3 (Nixx 9-11cell (8.0 V), A123 3S (6.0 V), Lixx (Low) 3S (8.4 V), Lixx (Medium) 3S (9.0 V), Lixx (High) 3S (9.6 V)
Option 4 (Nixx 12-14 cell (10.4 V), A123 4S (8.0 V), Lixx (Low) 4S (11.2 V), Lixx (Medium) 4S (12.0 V), Lixx (High) 4S (12.8 V)
Option 5 (Nixx 15-18 cell (13.2 V), A123 5S (10.0 V), Lixx (Low) 5S (14.0 V), Lixx (Medium) 5S (15.0 V), Lixx (High) 5S (16.0 V)
Option 6 (Nixx Not applicable, A123 6S (12.0 V), Lixx (Low) 6S (16.8 V), Lixx (Medium) 6S (18.0 V), Lixx (High) 6S (19.2 V)
Option 7 (Nixx Not applicable, A123 7S (14.0 V), Lixx (Low) Not applicable, Lixx (Medium) Not applicable, Lixx (High) Not applicable
7: Low Battery Cutoff Method:
Option 1 (Partial Cutoff)
Option 2 (Default) (Full Cutoff)
8: Reverse Power Limit:
Option 1 (25%)
Option 2 (50%)
Option 3 (75%)
Option 4 (Default) (100%)
Item 9: Drag Brake Strength
Works with: 4 (Option 1-4) 5 (Option 5)
Option 1 (Default) 0% 0%
Option 2 5% 12%
Option 3 10% 25%
Option 4 15% 37%
Option 5 20% 50%
Option 6 25% 62%
Option 7 30% 75%
Option 8 35% 87%
Option 9 40% 100%
This little controller is the only one I know of that has a Battery setting for the A123 style batteries with a 2.0V cut off and it has a setting for crawlers.
