Thanks guys
ilpufxit
ilpufxit's Avatar
Thanks guys - 12.22.2007, 06:20 PM
I'm going to try hardwiring first. If that still isn't it, I'll try the Quark. I was really hoping to run the MM since I have an extra one. Any input from other MM users on the best settings?
jordan...
one.five.two.seven
12.23.2007, 12:25 AM
how many cells are you running with that setup skillx?
skillx
skillx's Avatar
12.23.2007, 01:31 AM
4 now because I have a newer MM. But when I had an older MM i ran 5 all the time with no issues.
It is the motor!
ilpufxit
ilpufxit's Avatar
It is the motor! - 01.04.2008, 01:47 PM
I finally got back to this project. Using the Plettenberg, I swapped in my Quark 80b and the same cogging and extreme heating up occurs. I'm now convinced that there's something like a short in the motor. I have no continuity to the case on any wire but the heat build up is so fast that it could really only be a short.
BTW, with my feigao 8xl in the same set up with the MM, there is a little bit of cogging on start. Not much, but enough so you can't just grab WOT. With the Quark 80b, the cogging completely stops. Much smoother.
Is there anyone in N America who can fix this motor?
