stampedeproject
stampedeproject's Avatar
12.24.2007, 03:33 PM
Hmmm - the motor mount works great however - the rear brace needs to relocated or extended so it links up with the diff towers. Can't fit run a small pinion without having the edge of the motor bump into the brace. I may work fine for typical gearing, but I want some extra flexibility. I will keep you posted.
