rchippie
rchippie's Avatar
Post 12.29.2007, 10:28 PM
Originally Posted by squeeforever View Post
I think all you need is the ring and pinions, but the advantages are a lower gear ratio, so you can go with a smaller spur and lower the diff (using CR buggy diff mounts and/or RC-M motor mount depending on your motor mount setup). So basically, lower center of gravity, less rotating mass, and helical cut gears.
My bad i meant part #'s.
Are this the right ones ?.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJBM4&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXJBM3&P=7
REAL MEN RUN BRUSHLESS
