Apply fixed (measure) voltage - measure RPM
Spin with fixed (measure) RPM - measure voltage
Won't he need to use an AC voltmeter setting, and won't it give an RMS voltage out instead of the required DC input for the given speed? I can't find any info on how a 3 phase would be tested for kv.
Hey sikes sorry if you answered this but what was the final out come of your motor selection (I get dumb founded by the tech talk LOl)? I would like to attempt (direct to diffs) this with the maxx im building.
You are talking of the ESC right? I'm confused now
Have your test motor attached to ESC and Voltmeter to battery connector, leave battery unplugged. Spin motor shaft and record peak voltmeter readings.
Do not forget about RPM, you need to know motor speed to calculate Kv value.
