Patrick
Patrick's Avatar
01.02.2008, 08:04 AM
Yeah, I've used that 65t spur as well. It works ok after a few minutes with the dremel.
Because it's so big you might have to drill another hole in the standard motor mount plate or extend the adjustment slot a bit depending on the pinion you use.
