myndseye
myndseye's Avatar
01.03.2008, 09:40 AM
I had considered that when making my suggestion of the A123s. The first thing you need to address would be the power output match of a typical 8th in the small space that you are afforded for your conversion. I was looking around at the various batteries currently out, with your dimensions in mind, and nothing to meet your needs exists. The only hope you have would seem to be something you can quick change, akin to a fuel stop for a typical 8th. I don't really have accurate figures to go from, but it would seem that battery sizes (physically), are about 1 to 1 in runtime with the size of a gas tank when power output is that high. A typical 8th doesn't run that long without needing to be refilled, but I'd bet that if the tank was as large as a 6s high capacity battery, it could run that long.
myndseye
myndseye's Avatar
01.03.2008, 10:08 AM
I have since changed the car over to 5s1p, but you can imagine what I was talking about. Sorry about the cell phone pics.
ID:	3697   Click image for larger version
Countryhick
01.03.2008, 10:18 AM
Sorry myndseye, I made an error in my measurement of available battery space. It should of read like this.
H 27 mm
W 100 mm
L 160 mm
This is the available space under the radio tray. I still haven't decided where to locate the batteries. I'm also thinking if I use 3 seperate 2s1p 5000 mAh packs to get my 6s I can also use these packs individually for racing my 1/10 on-road. Mounting 3 seperate packs on the car wont be fun but at-least I will still be able to use the packs after the nitro 1/8 drivers ban me from racing, because I'm overtaking them down the straights.
cemetery gates
01.03.2008, 10:35 PM
H 27 mm
W 100 mm
L 160 mm
Uhm, why don't you use 2 3s1p maxamps 5Ah lipos?
http://www.maxamps.com/Lipo-5000-111-Pack.htm
They are 45mm X 138mm X 26mm so no need for 3 separate packs, only two...
Bye
Countryhick
01.03.2008, 10:39 PM
I race 1/10 electric on-road usually and the 2s packs are the only ones I can use under the current rules. So if I use 3 x 2s packs I can use them in my 1/10 and 1/8 (just better bang for my buck). Looks like I'm going to run these. http://www.trakpower.com/
Countryhick
01.05.2008, 09:31 AM
I now have a good idea of the hardware I need. Now I need to look at chargers and balancers. I have one of these already (only good for 4s I believe) http://www.robitronic.eu/elements/ap...erloader_e.pdf
1. What is going to be my best option for charging 3 separate "Trakpower" 2s packs at the same time?
2. I would like to get a balancer at the same time.
Recommendations please
Cheers Andrew
01.08.2008, 10:45 AM
Cheers Andrew
The charger in your link is good for up to 4s. Are you wanting to charge all three packs in series, or seperately? If in series, a single 6s capable charger and a balancer like the LBA10 will work fine. You'll just have to make a special type of Y charge and balance adaptor.
Sorry, can't help on the 1512 dimensions...
Countryhick
01.08.2008, 05:14 PM
I didn't, but I just whipped one up specifically for you.
The green circles are to show where you should zip tie the balancer leads to the main harness leads. The red wires with the gray ends show where those wires should either be removed from the connector, or put some heatshrink on them.
Hope it's not too confusing, but all I could come up with in a few minutes...
You mean like this Brian?
