Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
01.04.2008, 01:21 PM
Not a chance. The standard diameter for motors is 36mm, but the KB45 is 45mm in diameter- it wont be able to mesh properly without hitting the tranny. You could use a reverse motor mount though- mount one motor plate on top of the other, with some spacers inbetween, sandwiching the spur. You will need to make a custom second mount though, or modify the 2nd one, since the kb45 uses 4mm screws and has a 30mm mounting pattern (normal motors use a 25mm pattern).
