01.04.2008, 11:05 PM
Linc!
You mean you have a KB45 up your sleeve?
I have 3, a 10xl 8xl and a 10l, just can't beat the prices, I also have pinions with 6mm bore in 18t and 20t. They are only good for a plastic spur thought, not hardened. I have also had mike make me a 2 speed adapter with 6mm bore for my aftershock/lst project. I will run it with the 10xl (1200kv) on 9s lipo thru a cc hv85! Stock gearing gets me to 47mph in second, and doing the tranny gear swap should get me over 50. The lst is a big truck and 50mph should be fun! I think that the emaxx will get the 8xl and 6s lipo. Not sure what esc to use!
