Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
Insides of a KB 45 xl motor
Insides of a KB 45 xl motor - 01.04.2008, 11:25 PM
Not sure if anyone cares, but this is what one of these beasts looks like apart. The feigao motor behind the rotor is a 15l. The front end bell unscrews, quite easily on this one.
01.04.2008, 11:33 PM
Looks a lot like the internals of a Feigao motor (non slotted stator)...
01.04.2008, 11:37 PM
Very similar Brian, I would say that the build quality is very similar too. I do like the threadded endbell, should help it to stay together.
tashpop
01.05.2008, 12:18 AM
mine has came apart a couple of times on the shaft side. last time i used thread lock then soldered a small spot, then covered the seam with ca glue. its been holding since then, but i'm expecting it to come loose again. i would have done something better, but i was in the mood to bash, not wrench. its not coming apart from unscrewing either, it popped over a few threads which then allows it to move depending on accellerating or breaking.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
01.05.2008, 07:11 PM
Sounds like a 'Jumbo deluxe' sized RCM heatsink-clamp is in order...
tashpop
01.05.2008, 10:29 PM
that would be nice. i would be happy just to locate a heatsink for it.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
MetalMan
MetalMan's Avatar
01.06.2008, 02:12 AM
I've heard of the KB-45 motors being easy to take apart... My isn't so easy. In fact, I couldn't unscrew the front endbell at all, with the use of a rubber strap wrench and an adapter plate that basically stuck the front endbell to the vice.
That rotor is big, though!
Serum
Serum's Avatar
01.06.2008, 04:47 AM
What is that for a dent on th rotor? can it be that that's a cover for the actual rotor?
tashpop
01.06.2008, 10:58 AM
i don't remember mine having a cover over the rotor.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
neweuser
neweuser's Avatar
01.16.2008, 06:56 PM
If it's not a cover, it looks like on magnet and not sectioned.
big greg
03.01.2008, 02:11 AM
did you burn that motor up, the coils look fried
