david lamontagn
01.05.2008, 12:28 PM
Originally Posted by raptor50 View Post
I have futaba 3pk and the conversion.. Using Mamba max esc and I also have the CC bec and i want to use the mech. brake that was designed for. channel 1 is for steering, 2 is for esc and 3 is for the bec. then where do I put the plug for the mech brake? do I have to use a y connector or something? also, does any one know how to progrm the radio to use in conjunction to use brake servo and the motor at the same time?
one more thing.. how do I get rid of the brake in my ESC?
thanks..
Chanel 3 is not for the BEC. Your BEC should plug in the BAT slot of your Rx.
You plug the ESC in chanel 2 (remove the red wire of the ESC signal plug and insulate it if you use an external BEC) and your brake servo plug in chanel 3.
What you ave to do:
Set your ESC to the lowest brake setting, or if you can, cancel the brake in your MM programmation setup.
Now, set your Tx End point adjustment chanel 2, full trottle set at 100% and brake set at 0%.
now, set the chanel 3 End Point, full trottle set at 0% and full brake set at 100%.
Now, (i hope you have the MIXING fonction on you 3PK) mix chanel 2 and 3. Master will be chanel 2 and slave will be chanel 3.
So when you'll put full trottle, your ESC will give you full trottle and when you'll ginve full brake, the ESC will not brake but your brake servo will give you full brake.
I've the Futaba 3PM fASST 2.4gHz and an e-revo and it,s exactly like that i've setup it.
I've keep the two speed in the tranny, use the wide ratio and i'am gear 18/38 with a Neu 1515 1Y ad MGM 16018.
Hope i'll help you
Regards
David
