Did you connect the bec to the esc power leads? If you're still stumped do you have a rx pack you cann throw in and try that instead of the BEC?
Yep, maybe your CCBEC is toasted. Like said Matthew, try with a reciever pack on the BATT slot. And don't forget to remove the red wire on the ESC cable.
