Just a thought though, are you sure your XTM diff is like that.All the bevel gears i've ever seen are the same as the LST.The savage diffs are the same any way.The LST diff wouldn't be a bad choice though,and because it's a f/r diff you'll have one less set screw to check since on one side (in our case,on both sides normally) the shaft and outdrive cup are the same part.
