BlackedOutREVO
01.08.2008, 02:30 AM
Originally Posted by TRAXROB View Post
Thats it I can't take it anymore. Im buying the twin VXL's. When my wife finds out I'm telling her its madbaja's fault.
Yeah, for 300 bucks, its one heck of a fast/torque monster
How power hungry is it? What kind of run time do you get? And whats the heat on the speedo, and motors?
Serum
Serum's Avatar
01.08.2008, 03:04 AM
that's not 55 mph? i guess 40-45 mph tops.
01.08.2008, 03:24 AM
He can't be far off, unless the motor kv is way off spec, or the lipo voltage is really sagging under load. Check out the speed calc:
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.83
Spur Tooth Count: 65
Pinion Tooth Count: 22
Total Voltage: 11.1
Motor KV: 3500
Tire Diameter (inches): 7
Total Motor Speed: 38850 RPM
Vehicle Speed: 52.57 MPH
You have to factor wind resistance, but I did not account for tire ballooning, so he is most likely near 50 if not more. I find brian's speed calc to be quite accurate and that the tire expansion usually takes care of wind resistance, at least up to 70mph or so (I just leave the ballooninng section black). I always gear according to the speed calc and then check with my radar gun. Never more than 2-3mph off. My tamiya was actually almost dead on, but it has foam tires and a slippery body.
Patrick
Patrick's Avatar
01.08.2008, 03:15 AM
Yeah, it wouldn't have gotten that close to 55mph in than vid.
Serum
Serum's Avatar
01.08.2008, 03:42 AM
52 mph under ideal circumstances.
I i am not that far off with 40-45 mph linc.
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.08.2008, 03:52 AM
I was guessing about 40-45 myself...but the truck seemed to have quite a bit in the torque department...lifted those front wheels quite well...
Even my G2R with a 1940/7 on 4S and low gearing can't even pick the front tires up that fast. It more or less has to "pull them up." On the other hand, the COG and wheelbase is both lower and longer, respectively, than a new E...but even so the torque is impressive.
What I'm waiting for is someone to run two KB45's lol...
BlackedOutREVO
01.08.2008, 06:59 PM
Now that would be crazy!
The twin V's look good, 64 MPH is crazy, We do need a vid
01.08.2008, 10:35 PM
Me? I have 3 of them!
TRAXROB
01.09.2008, 10:37 PM
So I couldn't stand it anymore and I bought two Velinion systems and I am installing them tonight.
TRAXROB
01.10.2008, 12:45 AM
All done. Installed. I love them. Thanks themadbaja for posting that video. This thing is a monster and I have it on 2 - 5000 MAH 2s lipo's. I can't wait to get it on some 3s lipos.
TRAXROB
01.10.2008, 11:04 AM
Currently I'm running two 2s 5000 MAH racers edge lipos. What 3s's do you suggest?
themadbaja
01.08.2008, 07:22 AM
In the Video I was only going 1/4- 1/2 throttle.. I dont like to roll over on asphalt.
but With the 56/22 gears Its does 64 Verified very very hard to control
Serum
Serum's Avatar
01.08.2008, 07:25 AM
lets get a movie of that 64mph mt, that would be interesting..
01.08.2008, 10:59 AM
Ok, I thought that you were using a 65t sput, not a 56!!!
Changed up the speed calc and here it is:
Spur Tooth Count: 56
Total Voltage: 11.1
Motor KV: 3500
Vehicle Speed: 61.02 MPH
I did not use a value for tire expansion, so you must have some to raise the top speed a few mph. I am quite impressesd, what are you using to determine speed, a chase vehicle or radar? I have used both, but find it difficult for the chase vehicle to keep up! I bought a bushnell radar gun and it is much easier to use.
themadbaja
01.08.2008, 11:24 AM
What I did was My friend drove me in his ford edge and I drove the Emaxx he had to go about 63mph to keep up with the emaxx. I could only do 64mph for a short time very hard to control I need to adjust the shocks
