Its just that I have qty 4-5 3S cells ranging from 4000mah to 8000mah. So a Feigao or Hacker 7XL should get me the performance I'm looking for w/ 3S? What gearing would you recommend?
Without knowing what your setup is, tire, transmission gearing, spur gear etc... I cant really tell you.
http://scriptasylum.com/rc_speed/_top_speed.html
You can figure out what you need here. Just plug in your setup info. Gearing, batteries, motor, etc and you can figure out what you need to get the speeds you want.
to make it...
or break it...
