01.07.2008, 10:15 PM
The general wisdom is that for the larger nue motors a MM will not work as doesn't like the more than two pole motors...
If you are investing I would go for the MGM160.
I did a MBX5T conversion - I can recommend Mikes kit as it retains stock diff which is simpler.
