thats what ive been thinking but will the feigao shaft be long enough for the new emaxx,i know that the novak one is too short,and is the feigao a 5mm thick shaft?thanks for the quick reply,this forum is the best!
it should be long enough, what you can do is look at the feigao specs, find the shaft length by looking at the overall length of the motor then looking at the can length, whatever the difference between can/total is your shaft length, measure the shaft on your titan motor, and if the feigao is long enough, go ahead. ill see if i can find the shaft length for ya.
EDIT: the shaft length is 10mm.
