01.09.2008, 04:39 PM
The new emaxx tranny has a 33t output gear and a 18t input gear, ratio is 1.83. The feigao with 5mm shaft will be fine, I run an emaxx with a 15l on 5s and it worls fine, there is plently of shaft for the pinion set screw to hold onto.
