that could work. and both of those ESCs, they need an external BEC right? are they as strong and programable as the Mamba max? i know the mamba is rated for like 100A i think?
You can use a external BEC or a receiver pack just remember to remove the red wire from the controller. The MGM is somewhat confusing to program as some folks in the forum pointed out. The Quark is as programmable as the MM with out the PC capability. Keep in mind that in my opinion Castle over rates their controllers.
Why on earth would you say that?? The MM is only rated for 4S, yet the older ones can handle up to 5S. Even Castle reps said its good to go on 4S with the right setup, but it was just rated at 3S to cover there asses.
I got that from a few posts in rcgroups. Now I'm saying that from expirience as well as the Mamba seems to overheat easely. I have the new controller with the same set up that I had with the MM and it doesn't even break a sweet. Castle will be like Novak one day.
