thats what ive been thinking but will the feigao shaft be long enough for the new emaxx,i know that the novak one is too short,and is the feigao a 5mm thick shaft?thanks for the quick reply,this forum is the best!
it should be long enough, what you can do is look at the feigao specs, find the shaft length by looking at the overall length of the motor then looking at the can length, whatever the difference between can/total is your shaft length, measure the shaft on your titan motor, and if the feigao is long enough, go ahead. ill see if i can find the shaft length for ya.
EDIT: the shaft length is 10mm.
32p pinions with a 5mm bore, Mike has them in the store. I would suggest using BrianG's calculator to determine your gearing (aim for 35-40mph, and dont forget the new emaxx tranny has a ratio of 1.82 which you will need to enter manually):
The new emaxx tranny has a 33t output gear and a 18t input gear, ratio is 1.83. The feigao with 5mm shaft will be fine, I run an emaxx with a 15l on 5s and it worls fine, there is plently of shaft for the pinion set screw to hold onto.
excuse my retarded question but when you say 3/4 do you mean 3 cell 4 cell lipo and what king of speed can i expect with a 3 cell,thanks for all the help guys
I've got a MM esc also and will be usinga Ammo 36-56-2600 with 18t pinion. Motors are about $45-50 shipped most anywhere. The folks over at E-Savage.com recommend this setup and with the 3905 being 4oz more weight I'd say it'll work.
I'll keep you all up to date on mine when I get it up and running. It's on back order at Tower till late January. Probibly won't get it till Febuary.
