Whats the best way to mount a MGM 160 in the new maxx? I mounted mine using 2x tape, but after one run the Esc was warm making the tape loose. I wish the bottom were of plastic to mount it using the tape. I'm tempted to zip tie it to the shock tower.
You know they make zip ties with the little screw hole "ears" that may work using the stock mounting screw holes from the originl ESC. Might have to give those a go.
I found some 1" plastic mountaing squares at the local depot today. They have 2x tape on the bottom (good stuff) and these little slots on the top for slipping a zip-tie through it. It works very well without having to modify anything. Also in the pic I put together a switch mount since I had MGM include it when I ordered it.
