MetalMan
MetalMan's Avatar
01.16.2008, 01:33 AM
If you were to take complete advantage of the charger, you would need a power supply that can put out about 300watts (factoring in efficiency of the charger), which is about 23 amps at 13v. The only way to reach this charger's 250watt output limit is to charge 6s Lipo @ 10amps. Personally I think a 20amp power supply would be enough
