01.17.2008, 11:38 AM
Yep, a 3s 5000mah battery and a 6s 2500mah battey should produce the same runtime, if the correct kv motors are employed to produce the same motor speed and the gearing is the same. I have noticed that the hv setup seems to get slightly longer runtimes than expected. I think that boils down to the hv setup being more effecient.
