Patrick
Patrick's Avatar
01.19.2008, 12:27 PM
Only gear up if you staying with 4s. If you use higher voltage don't gear up until you see how it goes.
For normal use I would guess that 6s is a bit much on the 1y, but I'm not sure.
I'd just try 68/24 on 4s first and then go from there.
