sikeston34m
sikeston34m's Avatar
01.21.2008, 06:38 PM
The crazy thing about that motor is its based on a 5mm shaft and its turned down to 3mm where the pinion goes on it. I think they were aligning it to work with stock emaxx pinions.
I think like most outrunners its just a matter of losening a set screw that holds the shaft in place and replacing it with a 5mm shaft that isnt turned down on the pinion end. Should be easy to do if you can find a 5mm piece of rod and cut it to length. I could be wrong on that, but I think that is the case on most Outrunners.
Hey Jhautz,
You just described exactly what I did to the very motor I got from you. LOL
