Originally Posted by Edumakated
Ok... buggy it is. I think I am going with an rc8. I ordered an rc8 mount, tray, heat sink, and motor covers from Mike. What else do I need to make this conversion work? What 5mm pinion do I need? What kind of plugs are needed for the battery, motor, and ESC? Are people using Deans or Powerpoles? What amp size do I need?
You can use deans or traxxas connectors for the battery to esc. I usually direct solder the wires from the motor to the esc, as I have had issues with the bulet connectors. People use 5mm and larger connectors and report success, so you may try that.
