01.24.2008, 04:31 PM
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 87
Pinion Tooth Count: 17
Total Voltage: 7.4
Motor KV: 5700
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 5.12 : 1
Total Ratio: 13.95722 : 1
Tire Circumference (inches): 12.57 inches (319.19mm)
Total Motor Speed: 42180 RPM
Vehicle Speed: 35.96 MPH (57.77km/h)
Effective Speed Rate: 4.86mph/V (7.81kmh/V)
Effective KV Value: 5700
I dont know the diameter of stock tyres, but I guessed at 4" - says 36mph, which sounds about right.
