01.25.2008, 09:06 PM
I believe they sell 62, 65 & 68 tooth spurs for the 3905, and 12-22 tooth pinions. Changing one tooth on the pinion is roughly the same as changing 3-4 teeth on the spur, so it pays to have a selection of both really. 62/22 should give you about 35mph-ish, but I dunno if the spur and pinion will mesh- apparently the motor mount that is to the side of the tranny (rather than above it) offers you more adjustment space before the motor hits the tranny....
nitrorube
nitrorube's Avatar
01.26.2008, 12:36 AM
thanks alot
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
01.26.2008, 02:05 AM
Jato spur gears will fit the 3905 also. They are available with 54, 56, and 58 teeth.
